Cooling System Bleed Points - AudiForums.com
Reply
Thread Tools Search this Thread
Old 12-04-2011, 10:15 AM
madridlover's Avatar
Question Cooling System Bleed Points
So I need to bleed my cooling system since I still have an air pocket. Other than the bleed point next to the battery behind the firewall, are there other bleed points that are easily accessible on the '98 2.8L?
Can I just run the car with the cap off and rev it with the heater on for a while to expel the air bubble?
Thanks.
Old 12-04-2011, 11:54 AM
TwinTurboC5's Avatar
Default Bleeder Screw
Hi. On the 2.8L if you stand at the front of the car/engine and look down between the power steering pump and left cylinder head, there shuld be a coolant pipe there. Screwed into the top of that coolant pipe is a bleeder screw to evacuate air from the system. I believe its an allen fitting, but I'm not sure of the size. Once you have it open or loosened, simply fill the coolant resovoir until coolant begins to flow from the bleeder plug. Then you simply tighten it up. Once this is done, just keep a check on your temp gauge and coolant level...topping off when necessary to ensure that all of the air has been burped from your cooling system.
Old 12-04-2011, 12:07 PM
Quote:
So when you say "left cylinder head", if i'm standing in front of car I would looking to the right of engine bay?
Is this coolant pipe a small "L" shaped pipe?
Thanks again.
Old 12-04-2011, 12:08 PM
Also, where is the power steering pump located? is it right dead center of front of the engine?
Old 12-04-2011, 12:13 PM
Standing at the front of the engine and facing the windshield the left cylinder head will be to your right. The power steering pump should be centered and at the top of the engine. If you look down once you locate the coolant pipe, the bleeder screw should be on the top....basically looking you in the face.
Old 12-04-2011, 01:15 PM
I found it! Thanks! It looks like that coolant pipe is a metal pipe and not a rubber hose that I was expecting.
Reply
Thread Thread Starter Forum Replies Last Post
How to bleed air from cooling system kbunting Audi A6 2 04-13-2015 11:08 PM
a6 2.8 v6 C4 how to bleed cooling system? lionel a6 2.8 v6 c4 Audi A6 2 02-10-2014 06:07 AM
Need to bleed the system Vontropnats Audi A4 4 02-03-2008 07:00 PM
How to bleed cooling system please help carhopper S Car Model Line 5 07-22-2007 01:54 PM
how do you bleed the cooling system? lacrosse22 Audi A4 1 02-10-2006 10:34 PM
Tags
28, 98, a6, air, antifreeze, audi, bleed, bleeder, bleeding, car, coolant, cooling, engine, gt, leaking, locations, mustang, pipe, shape, system
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
