THIS IS CRAZY!!! WHATS WRONG WITH AUDI'S
ok first I have a bunch of codes I spend $1000.00 get al this changed;
1) spark plugs
2) Ignition wire
3) Coil
4)water temp sensor and sender
CEL came back on with and still misfiring
P0300
P0301
P0302
P0303
P0304
P0305
P0306
P 1141
P1522
P1519
NOW WHAT DO I DO?? where to start?
PLEASE HELP I DONT WANT TO SPEND CRAZY MONEY!
1) spark plugs
2) Ignition wire
3) Coil
P0300
P0301
P0302
P0303
P0304
P0305
P0306
P 1141
P1522
P1519
RE: THIS IS CRAZY!!! WHATS WRONG WITH AUDI'S
did u erased all codes after tune-up ? Hmm, best way is connect your audi thru VAG-COM and see, what's going on.
Check this for codes explanation http://www.2carpros.com/kpages/diagn...uble_codes.htm
look at this: http://tech.bentleypublishers.com/th...ID=78001#78001
for P1141 http://wiki.ross-tech.com/index.php/17549/P1141/004417
all codes u got here: http://www.brooklynautorennen.com/fo...fa1bfc149e6048
P1519 Intake Camshaft Contr.,Bank1 Malfunction
P1522 Intake Camshaft Contr.,Bank2 Malfunction
where is the Intake Camshaft?
17549 P1141 Load Calculation Cross Check Range/PerformanceIll clean the MAF
what about all the cylinder Misfiring??
You have camshaft faults on both banks? How many miles are on your car? I would be checking you timing belt it might have slipped a tooth or something. Pull off the cover and check how tight the T belt is.
update;
I put Lucas with Oil change, and lucas fuel cleaner drove about 200 miles now allcodes are gone except p0300 p0301,0302 etcmissfire on all cylinders
but yes I can feel the car Misfiring at low rpms like 7-800 RPM otherwise it drives perfect.
BTW I have 118k miles, will check the belts
No i would first check the timing belt ASAP! Even more so if you have 118k miles and don't know if it has been changed. If the belt has slipped enough to cause miss-fire faults it might not be long before it slipps enough teeth on the belt to bend valves in the cylinder head, don't drive it until you know its ok.
When checking the belt you shouldn't be able to twist the belt more than45 degrees.
