Disconnecting Odometer, Speedo & Tacho
I wish to disconnect my Odometer, speedo and tacho (temporarily). Does anyone know how this is done? I've done a search on here and on the net but can't find any info. They don't do a Haynes for my car either (in the UK at least).
I have a 2000 2.7t.
I have a 2000 2.7t.
RE: Disconnecting Odometer, Speedo & Tacho
search under swpping gauge I saw one in audiworld.
I don't it it was easy. just need to pull the pplastic part on top of the sterring, there is 2 bolts that goes out, and slowly jig the gauge and take connectors off from the side they are not that long. there should be 3 connectors to pull out.
ORIGINAL: WolfsA62.8Q
Yes, the instrument cluster can be disconnected/removed, but were you planning on driving it like that ? ( and why ? ).
I did a quick search as advised by tahoethp but couldn't find the thread. I'll keep searching....
2007, 2008, a6, a7, audi, disable, disconect, disconnect, disconnecting, odometer, spedom, speedometer, tachometer, unhook, working
