How to Change Oil on 2000 Audi A6 2.8Q?
RE: How to Change Oil on 2000 Audi A6 2.8Q?
audi diy ... its really easy just open oil cap then take oil plug out then take filter off then put filter on then put plug bake in n then fill with i believe close to 7 qts of oil n ur done
well do u think that your capable of doing this? ... if you have never changed oil b4 then you should probably just pay the extra 10 bucks it would cost to have ur indy mechanic change it... i dont mean to be rude
i dont have a pictures sry google maybe??
Hope this helps... this is a pic of the underside of my 01 A6 2.8 (sans the skid plate). IMO the hardest thing is removing the skid plate. Other than that its pretty simple. You can clearly see the filter and plug.
[img=http://img514.imageshack.us/img514/7955/oilbq9.th.jpg]
[IMG]local://upfiles/54523/11EF49194C4744E4BCFB1678DD680083.jpg[/IMG]
If you need that much help to change the oil, I would strongly advise you just to go to a professional and shell out the $50 and10 minutesfor them to do it... It's by far the easiest thing to do on a car, other than fill the gas tank. But you can definetly screw it up if you are completly dumbfounded by the bottom of the car.
