Sponsored by:
Sponsored by:
Error Code 441???
Old 08-22-2006, 08:20 PM
mikehh's Avatar
Default Error Code 441???
I keep getting the 441 error code on my 2000 A6 Avant, referencing to insufficient purge flow. Does anyone have a hint as to what to look for??
Thanks!!
Old 08-23-2006, 02:25 AM
dankhound's Avatar
Default RE: Error Code 441???
Evap purge valve stuck closed or a broken vacuum line from the purge valve to the engine. Do a search in the a6 and a4 forums. Operation and location is the same on both vehicles and theres plenty of posts to help you along.
Old 08-23-2006, 04:04 PM
mikehh's Avatar
i just replaced all vacuum lines, but i will ckeck for the valve.
thanks for the input!
Old 08-25-2006, 03:35 AM
dankhound's Avatar
If yo ujust replaced all the vacuum lines you may have one incorrectly routed. Also make sure the purge valve is plugged in. Both mechanically and electircally.
DCAV8R
01-23-2023 06:33 AM
aaceve7
09-07-2012 01:08 PM
shaikha
07-02-2008 04:39 PM
NewJ_A4
02-03-2008 01:09 AM
winter001
01-08-2008 07:50 PM
Quick Reply: Error Code 441???
