Sponsored by:
Sponsored by:
fault code show check engine light on?
Old 07-20-2007, 07:46 AM
thetryal's Avatar
Default fault code show check engine light on?
is there a specific fault code that would be present if the check engine is on? what if the CEL came on then went off? for the CEL to be on i understand that some sort of fault code would most likely be present, but i am asking for the code that specifically says the CEL was/is on? thanks
Old 07-20-2007, 11:49 AM
Jeffla's Avatar
Default RE: fault code show check engine light on?
It could be 1 of 500 different things. Go to Autozone, have them read the code and then post the results.
Old 07-20-2007, 11:54 AM
if the CEL goes off then it was an intermittent problem and a soft code will be stored and if it happens 3 times the CEL will stay on but until then I woudnt worry over it ( you could check the code for peace of mind at autozone ) then they could clear it
insanoman85
04-12-2010 10:58 PM
jeffwantsaaudi
12-20-2007 06:49 PM
shkenned
07-22-2007 06:28 PM
akindy
07-02-2006 04:01 AM
a4ddt
09-27-2005 02:01 AM
Quick Reply: fault code show check engine light on?
