Sponsored by:
Sponsored by:
Faulty Brake Switch Symptoms
Old 06-19-2008, 01:03 AM
fidelite's Avatar
Default Faulty Brake Switch Symptoms
In the winter my ABS light would randomly turn on (Disabling ECS as well), then off, reading the forums, it seemed to be a faulty ABS module. In the summer the ABS light became more steady and of course when I took it to Audi it would turn off for that day... Soon after I found I couldn't use cruise control, and after that all the brake lights in the back went out, if it got worse, it would basically not be able to come out of park. The part is $5.00 and the instructions kinda sucked, but once I replaced it, all the above started to work.
Hopefully this helps someone diagnose theirs
Old 06-19-2008, 07:50 AM
massboykie's Avatar
Member
Default RE: Faulty Brake Switch Symptoms
ORIGINAL: fidelite In the winter my ABS light would randomly turn on ...
I had exactly the same issues with the ABS light randomly turning on. The first tiem it happened it freeked me out, I reset it and could notsee anything else wrong with VAG-COM.Eventually took it in to let the warrantee take careof it...
Cheers
Massboykie
Old 03-16-2009, 12:07 PM
NH_USA's Avatar
where are you finding a brake light switch for $5?
jaredlipsitz
10-06-2014 03:29 PM
BigBadDave
B7 Models
23
09-17-2014 08:11 PM
98quattro
03-30-2007 05:58 PM
leelewis
07-11-2006 05:06 PM
AUDI A6 2.5 TDI
04-06-2006 08:21 PM
Quick Reply: Faulty Brake Switch Symptoms
