First Audi
First Audi
I Own A 2003 3.0 And It Has 73K On It, I Had Oil changed Yesterday And Now The Minimum Oil Light Is ON. do The 2003 Have Alot Of Promblems Like This? Such As Electrical Issues
If the oil level is correct and you're still getting the low fluid indicator I would suspect that the oil level sensor/sender is faulty. Check first to ensure that it hasn't come unplugged. If its plugged in, I would simply replace it with a new one. The sensor/sender is located on the bottom of the oil pan.
