First Time Poster- NEED EXPERT OPINION
So I've got a picture that I took in the engine bay of a 2001 Audi 2.7t. 133xxx miles. This car is priced at $6395, interior is a 9/10, exterior is a 9/10. But i'm not quite sure what's going on in this picture, and opinions would be GREATLY appreciated as to what this issue might be. I might try to super low ball them, and see if they take it. Then just take it to a shop and put the extra money straight into it.
I think the reason it looks so crusty is just from the heat in the engine vaporizing the moisture. Cheap and easy fix, see if you can get it from between 5500-6000. Check out the turbos, grill them about their driving habits, maintenance records etc. A turbo replacement is the most expensive repair on one of these bad boys
Check the top/rear of the bellhousing. There is a secondary water pump back there that is known to leak. You'll see the same pink/white evaporation crap on the top/rear of the housing. It's about $300 parts/labor to replace the pump.
Thanks by the way guys, this has all really helped.
Also check out that tee that the hoses are connected to I just did my water pump and when I went to remove those hoses the tee crumbled into pieces. I have never seen a plastic piece just fall apart like that.
