NO START NEED help PLS
a while ago i noticed my car was taking its time to turn over but it only happend once in a while so i never bothered to look into it. I have a A6 2.7 quatro 02 my check engine light is on but the last time i had it checked it was a O2 sensor falure. It didnt really bother me so just drove with it on. But now the car wont start at times.
I noticed the battery was weak and i replaced it but it didnt fix the problem. When i try to turn the car on it acts as if i have a kill switch istalled everything (electronic) works but the car just doesnt turn on after a numerous amonts of trys it finally does and when it does it hesitates i give it gas i get a iregular idle for a few seconds and then its ok but there is this smell that comes from the exhaust a heavy smell of what smells like paint thiner is throught the car in the engine bay and the exhaust it runs fine and nothings wrong but after a few days or maybe times of turning it off and on again as i drive it will happen again
any sug. ive looked everywere and it seems this is a special problem i have to take it to the stealer beacuse no mechanic in my area wants anything to do with it they say its a complicated problem i hope its not the timing belt or anthing elese around the 1000+ cost
PLS help
PLS help
RE: NO START NEED help PLS
CTS sensor, its about $40 at www.ecstuning.com Thats a good place to start, they are know for failure.
Vict0ar
04-03-2014 08:38 PM
kinnes042
S4
04-10-2013 06:29 PM
brit.mike13
10-17-2010 08:26 PM
