Dose any one know
Dose any one know
OK I HAVE POSTED HERE THREE TIMES AND NOBODY HAS REPLIED???
NOT EVEN A HELLO WELCOM TO THE FORUM.
I SEE THAT A LOT OF YOU HAVE LOOKED AT MY POSTS. IF NONE OF YOU CAN HELP ME WITH MY QUESTION THEN AT LEAST TELL ME THAT I AM WASTING MY TIME OR TELL ME WHERE I SHOULD GO.
lems-v8
Thank you I was starting to think that no one would talk to me
Im new at this fourm stuff so I hope you can help
I have a 2000 A6 2.7T that has no power going to the AC and heating control unit. I put my scanner on it and it says that relay 30 has low power. The fuse is good so I looked for were the relay would be but now I need to know which one is for the climate control unit.
if you can point me in the right direction I would reslly appreciate it
Hi, try this link, it might help you out with your relay 30 issue. Good luck
http://www.1600i.de/1600i-elektronik...heECUrelay.htm
