Sponsored by:
Sponsored by:
HELP- tranny fluid fill point?
Old 09-02-2007, 09:03 PM
mach1usmc's Avatar
Default HELP- tranny fluid fill point?
On just about any domestic I wouldn't have any problem finding this. But the Audi has me completely confused. Where do I fill the tranny fluid at? I can't even find a tranny dipstick under the hood of this thing. I know it's low due to the output shaft seal issues so I need to put some fluid in before something siezes up. I did several google searches to no avail?
It's an A6 4.2 AWD if that helps.
Old 09-02-2007, 11:18 PM
teranenrique's Avatar
Default RE: HELP- tranny fluid fill point?
I could be wrong but there is a "fill hole" that you insert your little tube in and pump Transmission fluid until it comes out, thats how you know that your level is full...anyone willing to confirm?
Old 09-03-2007, 04:33 AM
mach1usmc's Avatar
Is this fill point on the tranny itself? Front, rear, sides?Thanks for the reply.
Old 09-03-2007, 08:53 AM
jj2345's Avatar
the trannny fill hole is under the car itself,i did it myself just last month
Old 09-03-2007, 09:57 AM
phil13's Avatar
i did this awhile back. you have to have motor running to get to right level. the plug towards back is fill. one in front is drain. you have to put audi fluid back in or will have shift problems. trust me on this!!! its a bear getting it in also. don't try if not sure.
Old 09-03-2007, 12:00 PM
mach1usmc's Avatar
ORIGINAL: phil13
Awesome- thanks for the info. I have access to a lift so I'll just throw it up there. I know what you mean about shifts too- the fliud is slowly leaking out due to the leak and if you slow down too fast the tranny goes out of gear and or catches momentarily then slams back into gear. Parts are on their way but it'll probably be in the middle of the month by the time they get here.
Thanks again everyone for the replies- great help.
Old 09-03-2007, 12:01 PM
2k S4's Avatar
http://www.audipages.com/Tech_Articl...nsmission.html
Robin Schroeder
03-04-2011 03:33 PM
aamele8
02-13-2011 01:47 PM
fromerich
05-09-2010 08:48 AM
wolfdog
08-22-2007 11:55 PM
Team Loco
02-01-2006 01:20 PM
Quick Reply: HELP- tranny fluid fill point?
