High pitch squeak when turning
1998 A6 Quattro 172k
The front passenger side of my car makes a weird squeak noise sometimes when I turn. It only makes the noise when turning and not all of the time. I know noises are hard to diagnose without hearing them but does anyone have any ideas what the sound could be from?
Thanks
Thanks
Thanks
Thanks
IF that's good, you could have any variety of issues. Control arms, sway bar bushings bad, possibly tie rod ends....or your CV boot could be ripped which has allowed dirt to get in making a bad noise when turning.
The tie rods are good, they were replaced a little while ago. The control arms were swapped out about 2 years ago. The control arms did make squeaking noises but this is a different sound. The noise when turning and there is more force on the passenger side of the car. I will check the power steering fluid and see if it is low.
On man I have d same problem u have it usually happens when I turn d steering wheel on hard turns or making a U turns or making at left/right turn without really applying much brakes. And d noise is harder on d passenger side of d car.
Also I don't know if is happening to u or if is even related? When I'm parking d car d steering wheel make some weird noise as I'm turning it all d way to d left or right.
Now I had my control
Arms/tie rod/sway bars replaced, I check d fluid, is not low even tho it looks dirty. So maybe we have air on d steering lines/pump? Hope we could figured this out soon!
Thanks
Thanks
Nevalite
08-13-2012 03:04 PM
