Sponsored by:
Sponsored by:
How to change differential oil?
Old 01-28-2009, 09:51 PM
playboy00786's Avatar
Default How to change differential oil?
I have a 01 a6 2.7t and i was wondering if anybody knew of a good tutorial on how to change the dif oil for the front and back...or if anybody could tell me how to do it? Also what is a good dif oil to use along with capacities? Thanks
Old 01-28-2009, 09:53 PM
nm3210's Avatar
Is there a reason you're changing it??
Old 01-28-2009, 09:59 PM
Im at 120k miles and i was going to change it with my tranny fluid since my tranny is kinda slipping
Old 01-28-2009, 10:03 PM
nm3210's Avatar
Well, you're not technically supposed to do either - you at least realize that right? The tranny fluid is supposedly rated as lifetime. From what i've read on the forums, you're only getting yourself into trouble when you play with the tranny - i'm just obligated to give you the disclaimers of course.
Old 01-28-2009, 10:26 PM
nm3210's Avatar
Now with that said:
https://www.audiforums.com/forum/sho...d.php?t=116909
https://www.audiforums.com/forum/sho...d.php?t=123270
https://www.audiforums.com/forum/sho....php?p=1015798
Seems somewhere around 75w90 is good for the differential. Capacity should be 2 liters i believe. The front differential - again, i believe - is part of the tranny itself, so not a big deal there.
Can't find much for the differential, but this should get you started:
http://www.blauparts.com/audi/audi_f...on_fluid.shtml
Old 01-29-2009, 12:04 AM
hxgaser's Avatar
75W-90 synthetic will do for both front and back. Front is somewhat PITA. See here....
https://www.audiforums.com/forum/sho...d.php?t=110152
Old 02-25-2009, 09:48 AM
nathan3011's Avatar
The tranny fluid is rated as lifetime is it?? Wow that is something that I never knew about landlords insurance, guess you do learn something new every day.
Did you try to change it over, just wondered wether or not you were succesful in doing it??
achase1
01-19-2010 09:57 AM
kevin1533
05-04-2009 10:29 PM
speedys4
12-08-2008 07:59 PM
briguy3770
03-22-2008 01:13 AM
speedys4
03-13-2008 10:58 PM
Quick Reply: How to change differential oil?
