Sponsored by:
Sponsored by:
Oil leak...excessive?
Old 05-08-2010, 10:17 AM
02A6Beau's Avatar
Question Oil leak...excessive?
02 A6 2.7T Q Tip
I've been noticing a little oil leaking in area under the engine cover. Seems to be building up in bi-pipe, y-pipe, DV area. Just replaced my DVs about two weeks ago. I fear cranking the hose clamps any tighter than they already are. I had noticed a little oil there before and there was some in the hoses when I changed the DVs. I understand a little is to be expected, but how much is too much?
P.S. I also suspect that the oil is overfilled. Getting ready to do TB and related parts, alternator, and oil change with the correct amount this week. Is there anything else I should be looking for while its apart based on what I'm seeing above?
Old 05-08-2010, 12:23 PM
Jeffla's Avatar
Where under the engine cover?
Old 05-08-2010, 12:33 PM
02A6Beau's Avatar
right around the connections from the bi-pipe to the DVs and throttle body boot. I know the TBB is a common cracking/fail point but mine appears to be in good condition
Old 05-08-2010, 12:54 PM
Jeffla's Avatar
I know very little about the 2.7, but isn't all that on the rear of the engine? Could it be from the cam seals/valve cover et al leaking down onto other stuff?
A6Isaac
02-10-2014 06:56 PM
wolvrishu
10-23-2013 10:32 AM
patitafrita
08-29-2013 11:12 AM
burtonsnow13
08-06-2010 11:54 AM
Oafy22
B7 Models
10
01-05-2009 10:55 AM
Quick Reply: Oil leak...excessive?
