what catalytic converters to use?
had the codes checked at autozone they say i need to replace my cats on my 2000 audi A6 2.7t.
I have been looking around and have found Eastern Catalytic makes cats for this car for $57 for each cat which is extremely cheap. Has anyone used an Eastern? Then there is catco and D.E.C. for $300-400. Are there any good aftermarket high flow cats that work good with an o2 sensor hole for this vehicle.
thanks
thanks
RE: what catalytic converters to use?
You get what you pay for. Now I am known for being the cheapest SOB you will ever meet, and I don't think I would even go with the 57.00 dollar ones. But then again if you are going to do the work yourself, if you spend 114.00 for the cheap ones and they fail in a year, you are out very little money. Might be worth the risk. Have the codes come back yet?
Jeff
Jeff
I am in the same boat you are in with 00 2.7T. I have seen the exact same cats you have seen. I would not go for the cheap cats. I need to replace mine but I have a Milltek cat back exshaust so I am getting my last few bucks together to purchase Vast piggie DP's which include new cats!
OOOO
OOOO
i just hit 98000. i just checked out the vast site and have a few questions. so for that 395 i get both sides correct? also with the piggie pipes will that set off any codes and can i use the normal o2 sensors? how hard is it to pull off the downpipes? i heard you have to drop ur rear subframe and detach your tranny.
thanks
thanks
ORIGINAL: domvr6
thanks
thanks
They are a ROYAL PITA to get off & replace. If you DIY, it WILL take you over a day. The passenger side is not hard, it's the top nut on the drivers side that sucks!
why wouldnt they accept them back? Do they take the core ones and then make them piggie pipes and put different cats on them? I just dont understand why they couldn't take it. It's illegal to sell a used catalytic converter so if they were reusing these pipes im sure theyd be changing the cats.
ORIGINAL: domvr6
OOOO
If it were me, I'd be getting the Magnaflow spun cats that appear to be a higher-flow, direct fit (at least from what I saw under my 4.2). And probably the )2 relocators, just to be safe.
http://www.car-sound.com/02product/u...al/549spun.asp
where do i need to relocate the o2 sensors to? will the piggies cause me to get a code and thats why i need to relocate? Do these DPs come with relocated spots?
