Memory Seat Setting Help? - AudiForums.com
Reply
LinkBack Thread Tools Search this Thread
Old 10-14-2006, 02:24 PM
Default Memory Seat Setting Help?
Hi Guys,
I recently bought a 2003 A6 without the owners manual. I've been trying to set the drivers seat using the memory button and the 3 option buttons, but with no luck.
Could someone please come to my aid and tell me the proper procedure for saving the seat options into memory?
Thanks
Eric
Old 10-17-2006, 02:02 AM
Default RE: Memory Seat Setting Help?
hold the hold button at the same time you hold the memory and then the # button. it works for my 01 a6. you should look into getting a manual, it will help you with everything concerning the car, and probably tell you some things you never knew existed with it.
Old 10-17-2006, 02:08 AM
Eric,
look here. it's good to have one, and for $30 it's a pretty good deal
http://cgi.ebay.com/ebaymotors/2003-...spagenameZWDVW
Old 10-17-2006, 01:35 PM
Before you buy a manual, take a look in the storage compartment located underneath the steering wheel. (I had to ask the PO where the manual was located, I never would have looked there!) You can buy the owner's manual for about $15.00 from the VW-Audi publications website http://www.audi.ddsltd.com
Good luck.
Old 10-17-2006, 02:23 PM
AQ6 AQ6 is offline
The following directions are right from my manual, hope it helps.
1 Stop button depressed
2 Adjust drivers seat
3 Adjust outside mirrors
4 Adjust steering column (if available)
5 Press M button and hold. At the same time press one of the three numbered recall buttons for atleast 1 second.
6 Release the M the recall button
The positions are now assigned to that paricular recall button and stored in the memory.
Old 10-19-2006, 09:17 PM
ppgoal's Avatar
There is also a shelf under the jack (in the left rear quarterpanel). I keep my manual there.
2003 A6 2.7T 6-speed
Old 10-21-2006, 01:55 AM
Thanks guys for your much needed help . And i will have to purchase the manual as its not in any of the cars interior panels. The ebay price sounds very reasonable, i think ill purchase it from there. Thanks again thetryal, ppgoal, AQ6, alfisch91 and jtehan. Your inputs were very much appreciated.
Old 07-15-2013, 07:24 PM
kenny p's Avatar
Thanks guys, it works great. going to buy the manual.
Reply
Thread Thread Starter Forum Replies Last Post
Memory seat Rivertest1 Audi A6 0 08-24-2013 02:35 PM
C5 Seat Memory Problem dberberick Audi A6 2 05-31-2013 12:18 PM
Fingerprint input and one-touch memory setting problem - 2003 A8 (D3) Suj85 Audi A8 1 11-18-2012 07:29 PM
seat memory Polka Salad Audi A6 4 07-08-2007 02:10 AM
96 A6Q Memory seat reset tolazy2 Audi A6 2 09-10-2005 05:30 PM
Tags
2003, 2005, a3, a4, a6, audi, button, instructions, memory, program, seat, seats, set, setting, stop, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
