Sponsored by:
Sponsored by:
Memory Seat Setting Help?
Old 10-14-2006, 01:24 PM
zulu411's Avatar
Default Memory Seat Setting Help?
Hi Guys,
I recently bought a 2003 A6 without the owners manual. I've been trying to set the drivers seat using the memory button and the 3 option buttons, but with no luck.
Could someone please come to my aid and tell me the proper procedure for saving the seat options into memory?
Thanks
Eric
Old 10-17-2006, 01:02 AM
thetryal's Avatar
Default RE: Memory Seat Setting Help?
hold the hold button at the same time you hold the memory and then the # button. it works for my 01 a6. you should look into getting a manual, it will help you with everything concerning the car, and probably tell you some things you never knew existed with it.
Old 10-17-2006, 01:08 AM
jtehan's Avatar
Eric,
look here. it's good to have one, and for $30 it's a pretty good deal
http://cgi.ebay.com/ebaymotors/2003-...spagenameZWDVW
Old 10-17-2006, 12:35 PM
alfisch91's Avatar
Before you buy a manual, take a look in the storage compartment located underneath the steering wheel. (I had to ask the PO where the manual was located, I never would have looked there!) You can buy the owner's manual for about $15.00 from the VW-Audi publications website http://www.audi.ddsltd.com
Good luck.
Old 10-17-2006, 01:23 PM
AQ6's Avatar
AQ6
AQ6 is offline
The following directions are right from my manual, hope it helps.
1 Stop button depressed
2 Adjust drivers seat
3 Adjust outside mirrors
4 Adjust steering column (if available)
5 Press M button and hold. At the same time press one of the three numbered recall buttons for atleast 1 second.
6 Release the M the recall button
The positions are now assigned to that paricular recall button and stored in the memory.
Old 10-19-2006, 08:17 PM
ppgoal's Avatar
There is also a shelf under the jack (in the left rear quarterpanel). I keep my manual there.
2003 A6 2.7T 6-speed
Old 10-21-2006, 12:55 AM
zulu411's Avatar
Thanks guys for your much needed help . And i will have to purchase the manual as its not in any of the cars interior panels. The ebay price sounds very reasonable, i think ill purchase it from there. Thanks again thetryal, ppgoal, AQ6, alfisch91 and jtehan. Your inputs were very much appreciated.
Old 07-15-2013, 06:24 PM
kenny p's Avatar
Thanks guys, it works great. going to buy the manual.
Rivertest1
08-24-2013 01:35 PM
dberberick
05-31-2013 11:18 AM
Polka Salad
07-08-2007 01:10 AM
tolazy2
09-10-2005 04:30 PM
Quick Reply: Memory Seat Setting Help?
