Sponsored by:
Sponsored by:
Missfire on Cylinder 5,6,7,8
Old 05-05-2013, 12:41 PM
bigozzyfan4life's Avatar
Default Missfire on Cylinder 5,6,7,8
I have an 03 A6 4.2 that has a CEL on. It flashes when under load on the interstate or going up hills and the car shutters before downshifting. I took it to Advance and they told me I had multiple misfires on 5, 6, 7, and 8. I replaced the camshaft sensor and all spark plugs. This didn't work. That leave me a few other options. Coil packs or the ICM? Being that the problems on the right side of the motor I could assume it's not the coils. Any other ideas?
Old 05-05-2013, 04:25 PM
Nebuchadnezzar's Avatar
It could be an ICM issue. You can try taking the ICM out and turning it around and then re-install it to see if the problem jumps to the other side of the engine. If so, then you know it's your ICM.
Old 05-05-2013, 06:47 PM
Thanks. I'll try that.
Old 05-07-2013, 07:26 PM
Ok, so where is the ICM located, lol?
Old 05-07-2013, 09:19 PM
It's ok, I had to do some thinking myself for a second. Follow your coil pack wires to your ICM. There are two: bank one and bank two. Simply swap them around and see if the problem goes to the other side. If so, then you found your problem. I have a feeling that this is probably what you'll find.
Old 05-20-2013, 10:18 PM
Is there a picture showing where this is at? I cannot locate the ICM. I'm no mechanic, lol.
DjSly
04-28-2009 01:25 AM
audia4boy24
07-24-2008 01:33 PM
eurwaudi1.8
11-14-2007 08:08 AM
dj_lex
11-05-2007 08:03 AM
2000turbo
02-11-2007 07:51 PM
42, a6, c5, icm
Quick Reply: Missfire on Cylinder 5,6,7,8
