Sponsored by:
Sponsored by:
My 2005 A6 won't start
Old 01-19-2015, 05:19 AM
ojennings's Avatar
Angry My 2005 A6 won't start
Can someone please offer some suggestions? I just bought a 2005 A6 3.2 Quattro. For some reason it just won't start. The engine turns coughs like its about to start but it won't start. My mechanic says it's getting plenty of fuel pressure. Any suggestions would be greatly appreciated. BTW it has 178K miles.
OJ
Old 01-19-2015, 09:15 AM
PaulRodgers's Avatar
Just call the previous owner for best advice.
Old 01-19-2015, 10:07 AM
twopedalwarrior's Avatar
Now that is bad advice
What is the service history and have you checked codes?
What is your battery status?
Alternator?
Coil pack etc...
Old 01-19-2015, 11:35 AM
ojennings's Avatar
I have tried to check codes. I get an ECM error code the won't allow me to check codes.
Old 01-19-2015, 11:36 AM
ojennings's Avatar
The battery is definitely low. I've been hooking up a charger to it in order to get it cranking.
Old 01-19-2015, 04:54 PM
sheldon's Avatar
The low voltage is also the reason you cannot pull codes. Right before my battery died I got ECU errors as well and couldn't run diagnostics.
Since you know the battery is already possibly bad - get that checked. Have your alternator checked while you are at it. Check for codes again when that's squared away.
Once you got good power, good fuel - that leaves spark, air and timing/sensor related gizmos.
Old 01-20-2015, 12:51 AM
ojennings's Avatar
Thank I'm going to get right on it in the morning.
Old 01-21-2015, 08:20 AM
ojennings's Avatar
Default @005 A6 still not starting....
It's back to the drawing board. Battery all charged up and the car still won't start. Searched the "All Data" page and all they could provide was information on cars with the keyless start. My 2005 A6 doesn't have that. My car starts with a key. It cranks one time then stalls out. Any other suggestions?????
Old 01-21-2015, 01:42 PM
sheldon's Avatar
So let's back up a little - from your initial description it reads like you bought the car and pretty much the same day it didn't want to start anymore? Has the car ever started since you owned it? Has anything happened since it started and since it wont start anymore?
I'm asking because if you don't know the history of the car and it never started since you owned it anything could be the fault - even timing belt.
Also without error codes you would have to go through all the little devices involved in getting the car started. You checked for fuel, battery. Now you still need to check if you get proper spark, air, computer response (ECU), timing, crank sensor, etc.
Are you sure you cannot (with a freshly charged battery) check for stored codes? Not even the standard CEL codes?
mikeyb291
06-09-2013 04:09 PM
dleslie3183
04-23-2013 10:45 AM
Frencho
12-14-2012 05:47 PM
Big Diesel A8L
01-04-2010 01:04 AM
aerostatwv
12-20-2009 09:27 PM
Quick Reply: My 2005 A6 won't start
