Need Help With Fault Codes
2001, A6, 2.7T, manual shift, maintenance is up to date.
Was driving yesterday, engine died, no warning or previous issues. When I tried to start the car, the car turns over, but won't start. Had towed home, hooked to vag com the following are the codes that come up.
p1392Camshaft Pos.Sensor,Bank2 Open Circ./Short to B+
p1338Camshaft Pos.Sensor,Bank1 Open Circ./Short to B+
p1654Please check DTC Memory of control panel ECU
p0116Engine Coolant Temp.Circ Range/Performance
p1131Bank2-Sensor1 Internal Rsistance too High
p0431 warm up catalyst efficiency below threshold bank 2
Any suggestions on where to start?
Thank you for your suggestion. Please forgive me, as I am new to this, so I am trying to figure out the best way to ask things. Would the cam shift sensor, stop the car from starting? Can the cam shaft sensor going, cause some of the other codes to read? Would clearing the codes, let the starter engage? Would a fly wheel cause the above errors or symptoms? Any suggestions would be awesome.
