Sponsored by:
Sponsored by:
need help with retiming cams on bel a6 2.7t cam heads - 2003
Old 01-20-2013, 12:19 PM
sandog79's Avatar
Default need help with retiming cams on bel a6 2.7t cam heads - 2003
I had my heads valve stems redone and the machine shop disassembled them. I have enclosed some pictures and was wondering if anyone know how to reset the timing on these . Thank you in advance.need help with retiming cams on bel a6 2.7t cam heads - 2003-img-20130118-00079.jpg
need help with retiming cams on bel a6 2.7t cam heads - 2003-img-20130118-00080.jpg
need help with retiming cams on bel a6 2.7t cam heads - 2003-img-20130118-00081.jpg
need help with retiming cams on bel a6 2.7t cam heads - 2003-img-20130118-00082.jpg
need help with retiming cams on bel a6 2.7t cam heads - 2003-img-20130118-00083.jpg
Old 01-20-2013, 12:22 PM
sandog79's Avatar
need help with retiming cams on bel a6 2.7t cam heads - 2003-img-20130118-00084.jpg
need help with retiming cams on bel a6 2.7t cam heads - 2003-img-20130118-00085.jpg
need help with retiming cams on bel a6 2.7t cam heads - 2003-img-20130118-00086.jpg
need help with retiming cams on bel a6 2.7t cam heads - 2003-img-20130118-00087.jpg
need help with retiming cams on bel a6 2.7t cam heads - 2003-img-20130118-00088.jpg
Old 01-21-2013, 07:17 PM
hxgaser's Avatar
I am not trying to be a smart ***, but you need to get yourself a Bentley or a manual of some sort. In order to set the timing correctly, there are a few things to do in sequence. First the alignment of the intake cams to the exhaust cams connected with cam chains and properly loaded tensioner for both banks... Two, alignment of the exhaust cams to the crank itself. You will need proper tools to do all of this. They are:
- Cam chain tensioner tool.
- Cam lock bar
- Crank lock pin
Old 01-22-2013, 10:44 AM
sandog79's Avatar
I have myself the bentley manual, just bought it. It does not contain any information, at least non that I could find, on how to put the cams back into timing. I have 2 of the cam chain tensioners, the cam lock bar I will rent when it is time, and the crank lock pin, I have yet to hear of, but it looks like I will not need it till the timing belt goes back on. Currently though, I need to put the cams in the heads back first.
Old 01-22-2013, 10:32 PM
hxgaser's Avatar
You asked for it. Here is some reading...
https://www.audiforums.com/forum/aud...-a6-up-174154/
Garrett8
06-11-2015 10:15 PM
justinclink1
11-15-2010 05:28 AM
jhuffman
06-25-2010 01:47 PM
pimphell
10-20-2009 03:02 PM
tooxtreme8813
01-14-2008 02:15 PM
Quick Reply: need help with retiming cams on bel a6 2.7t cam heads - 2003
