Sponsored by:
Sponsored by:
P1423 Bank 1 Air Flow Too Low
Old 01-12-2010, 09:32 AM
Deekster22's Avatar
Default P1423 Bank 1 Air Flow Too Low
I've had a check engine light on for a while now and the code is P1423. I had it checked and was told to replace the passenger side O2 sensor and to check the vacuum lines. Well I had both replaced and I still have the light come back on. Any ideas what else might be causing this?
Old 01-12-2010, 12:53 PM
NH_USA's Avatar
I would have done the O2 sensor after everything else -- Check the combi valve, make sure the passages are clear, and the lines from the air pump are not cracked.
tdawley
08-15-2013 03:49 PM
Mardimus
12-07-2012 01:24 PM
Jpadguy
08-03-2012 01:21 PM
dmillrod
05-18-2011 12:15 PM
Quick Reply: P1423 Bank 1 Air Flow Too Low
