Please help ID Warning Symbol
Hey Guys,
I can't seem to find this symbol in the book or online,
Car is a 01' A6 Avant 2.8 Quattro,
Symbol looks like a yellow triangle, inside that yellow triangle is a "!", around that triangle is a circular arrow going around the triangle in a counter clockwise direction.
I have a code for Central Locks, is that for the locks???
Thanks very much!
Thanks very much!
Hey Guys,
Thanks very much!
Thanks very much!
the sign should not be on unless you pressed the button.
I'll check it in the morning when its light again, so you are saying whenever the button is pressed that symbol will appear.
When you shut down the engine and restart is still there, the ABS light I notice is on as well. I just put in a new steering module because of ABS problems.
Trying to make all these light go out!
Thanks
Thanks
Thank You!
