Power Steering Groan - affected by outside temp?
I thought I read someplace that our power steering racks are a problem on these cars. Could this be causing my symptoms?
Update:
Now that it's gotten considerably warmer outside the noise has begun to creep back. It's gotten above 90 degrees two days of last week and it began sounding like the dying animal the OP mentioned in his thread.
I checked the fluid and it's fine. What can be causing this? Should I replace my steering rack? I'd hate to spend $400 on a new steering rack plus labor only to have the noise remain.
Anybody????
Anybody????
Replace your clamps first with non-perforated worm drive clamps. Audi has them or search them on line. You could be sucking in air. especialy from the one on top of the pump. Mine did that after I changed the belt and moved it around. For now tighten the single use clamp some more.
After I changed my fluid to the G400 fluid from Audi and changed the clamps mine went away and did not come back.
Having same problem on my 2000 A8... 80,000 miles. Horrible groaning sound when parking or making slow speed turns. No noise at all while driving. Given the commonality of this problem, I am surprised that there does not seem to be a "stock" answer that takes care of it! Help?
Thank you!
Thank you!
I had the noise for months getting slowly worse, then one day close to home, the accessory belt went loose, a belt tensioner had come apart. I replaced the tensioner and belt and the noise went away. Car had ~120,000 miles.
#18
It was mentioned already but, I have found a common cause is the hose at the pump becomes stiff over time and even with new clamps will not seal air tight. It does get worse with cold temps, can also happen at any temp though. You won't have any fluid leakage but air will get sucked into the system (since it's the suction side hose leaking) and aerate the fluid, causing the groan similar to a what low fluid will do. Eventually, if left alone it will damage the pump. The air bubbles actually "explode" (simplest way to describe it) when the fluid is pressurized and erodes the pump vanes and housing bore.
#19
so the mercury has crept lower here, north of the 49th and my Steering is super noisy on start up and for the first 20min of driving... I suspect the fluid, thought being that once it has warmed up either by use or by conduction under the hood, the fluid is more viscous
Anyone know if, like brake fluid, PS fluid can slowing pull moisture in from the air?
I think this is a viscosity problem with the temp dipping and making the fluid more like molasses...
I'm going to try some 100% synthetic PS fluid as a fix.
What's this G400 Fluid I saw mentioned? Just overpriced generic power steering fluid with an Audi logo on it or is it something substantially different?
#20
Hi, don't even bother to replace just the fluid. The PS pump is busted and needs to be replaced. It doesn't cost that much. All pumps are refurbished (rebuilt) anyway. Even dealer sells them rebuilt and sells as new. I bought one as OAM and have no issues. Works great. Hope that helps.
