Side Marker bulb - AudiForums.com
Reply
Thread Tools Search this Thread
Old 05-09-2007, 03:55 PM
Default Side Marker bulb
I was curious to see how you can remove the side marker bulb? I get nervous trying to remove the cover for it thinking it may crack. Can someone help me on this?
Thanks guys
Old 05-09-2007, 04:51 PM
Default RE: Side Marker bulb
What model year do you have? On my 00 2.7T, you can use a very small screwdriver and gently push in the tab and the unit will come right out. The clip is only on one side so once you push it in, you lift that side first and the other end will slide out by itself. Hope that helps!
OOOO
[IMG]local://upfiles/13659/2329EC9F4A95456B944E5008564ACE47.jpg[/IMG]
Old 05-09-2007, 06:47 PM
smtcapecod's Avatar
I did it by hand when replacing my sidemarkers with smoked units from ECS. Just push rearward and then tip out.
Perhaps even cooler than smoke on some cars, madaudi.com has body-color sidemarkers..
Reply
Thread Thread Starter Forum Replies Last Post
How to replace rear marker light bulb haidangwa Audi Q7 0 02-01-2010 11:29 PM
side marker went out gabe711 B5 Models 7 06-25-2008 10:56 PM
side marker help pattycakes77 B5 Models 7 05-18-2008 09:02 PM
Side Marker Euro S4 S Car Model Line 1 03-06-2007 06:35 PM
clear side marker? smoked side marker? ibe3pac Audi A4 8 01-26-2006 09:37 PM
Tags
2007, 928, a4, a6, audi, blinkers, bulb, change, changing, cover, lens, marker, porsche, remove, side
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
