Sponsored by:
Sponsored by:
Side Marker bulb
Old 05-09-2007, 03:55 PM
EnviedA6's Avatar
Default Side Marker bulb
I was curious to see how you can remove the side marker bulb? I get nervous trying to remove the cover for it thinking it may crack. Can someone help me on this?
Thanks guys
Old 05-09-2007, 04:51 PM
Joeski's Avatar
Default RE: Side Marker bulb
What model year do you have? On my 00 2.7T, you can use a very small screwdriver and gently push in the tab and the unit will come right out. The clip is only on one side so once you push it in, you lift that side first and the other end will slide out by itself. Hope that helps!
OOOO
[IMG]local://upfiles/13659/2329EC9F4A95456B944E5008564ACE47.jpg[/IMG]
Old 05-09-2007, 06:47 PM
smtcapecod's Avatar
I did it by hand when replacing my sidemarkers with smoked units from ECS. Just push rearward and then tip out.
Perhaps even cooler than smoke on some cars, madaudi.com has body-color sidemarkers..
haidangwa
Audi Q7
02-01-2010 11:29 PM
gabe711
06-25-2008 10:56 PM
pattycakes77
05-18-2008 09:02 PM
Euro S4
03-06-2007 06:35 PM
ibe3pac
01-26-2006 09:37 PM
Quick Reply: Side Marker bulb
