Sponsored by:
Sponsored by:
spark plugs changed, now wont start
Old 04-25-2007, 12:07 AM
goc305's Avatar
Default spark plugs changed, now wont start
Hey everybody, i just changed plugs and plug wires(also had to change left side valve cover gasket), and now the car wont start. It made a clicking noise but did not turn over. I replaced wires one at a time so i wouldnt get them mixed up. Any suggestions? 1999 a6 quattro. Thanks for the help.
Old 04-25-2007, 01:40 AM
Jeffla's Avatar
Default RE: spark plugs changed, now wont start
Sounds like a dead battery
Old 04-26-2007, 02:12 PM
goc305's Avatar
changed battery(it was dead), started but ran horrible (stuttering at approx 500 rpm idle). 2 possible scenarios: 1.) plugs are not plugged into correct coil (I was very careful replacing them one at a time, but if anyone has a diagram or picture, that would be great). i have the bentley manual, but it only shows drawings of the 2.7t, where i have the 2.8. 2.) on the left side cylinder head cover, the sensor that plugs into it, the tube snapped where it crosses the engine. i have noidea what this is, but will try to elecrical tape it to get it running properly. any other thoughts or suggestions would be greatly appreciated. Thanks.
Old 04-26-2007, 02:20 PM
Jeffla's Avatar
My first thought is you need to do a throttle body adaptation.(sp) Start the car a few more times if you don't have a vag-com and see if it clears itself up. I believe the tube you are talking about is part of the breather system, mine was cracked for a long time and when I finally fixed it, it didn't seem to make any difference. Well except for the oil smell in the cabin went away.
When the battery is disconnected/dead for a while you have to readapt your throttle. I assume that all C5 A6 2.8l engines use drive by wire. If you have an actual throttle cable I don't know if you need to do the adaptation.
Find a vag-com if you don't have one. Also I assume all the wires are secure and you put wire 1 to cylinder 1, 2 to 2, 3 to 3.....
Jeff
Old 04-26-2007, 03:00 PM
goc305's Avatar
ok, so i had the 4 and 5 plug wires mixed. did i do any major damage?
Old 04-26-2007, 05:44 PM
goc305's Avatar
i am continuing to crank the car and let it run for a few minutes. It seems to bounce around at idle between 500 and 250 rpms. thoughts? Thanks.
Old 04-26-2007, 06:58 PM
firing order is 143625 from the coil pack
engine layout
6-5-4
front of engine------
3-2-1
what was this sensor pipe you broke and do you have a picture?
Old 04-26-2007, 07:22 PM
goc305's Avatar
I found the engine layout stamped under the coils, it is different than what you have in your post. I can take a picture, but how would i attach it to this post?
Old 04-26-2007, 07:29 PM
[IMG]local://upfiles/12092/232E0BB2333C4F3D84D96793412C399E.jpg[/IMG]
Old 04-26-2007, 08:10 PM
goc305's Avatar
i see what you're sayin, but stamped right in front of the coil pack, is:
5 4 6
3 2 1
i am going to take pics in a while.
that is neither here nor there, any ideas why this car wont idle?
Quick Reply: spark plugs changed, now wont start
