Sponsored by:
Sponsored by:
Stuck in Park / EPC / Check Engine
Old 04-23-2013, 10:36 AM
bsmterp's Avatar
Default Stuck in Park / EPC / Check Engine
2006 A6 3.2 w/ 64K miles; Here's my tale in 3 events with reference to the following thread https://www.audiforums.com/forum/gen...lution-167276/
This thread was helpful, but I'm not convinced it the TCU.
Events occur over the course of 5 days:
1) locked in park, EPC and check engine illuminated, pulling a p0706 code - I have it towed, the code cleared and it runs fine
2) TCS and check engine light on, limp mode - I drive it 2 miles to my favorite shop, they replace engine coil good as new - I also have the ft brakes redone
and the is a continuing annoyance of a adaptive light defect
3) 3 days later - AGAIN - locked in park, EPC and check engine illuminated; again I have it towed
I don't have code for the last 2 events.
One of the other symptoms I've noticed is infrequently (1 out of 5-10 times) when I turn the key in the ignition, instead of starting immediately, there is a brief pause after the first firing and this has been happening for month without degradation.
I could be avoiding the obvious (TCU) but I'd hate to replace that and find out its something else. Can anyone think of something else to try first or is it the TCU?
Also looking for a way to get it out of park. I took out the ashtray and see 2 screws but not cover or hole to access the 'white button' referred to in other posts.
Old 08-23-2014, 03:24 AM
MrDeletion's Avatar
Question How was this solved for you?
Hi Guys!
Eagerly trying to get some help with my A6s EPC issue.
I am seeking solutions or your knowledge with a similar issue.
Please see my post here, and reply if you can help me in any way:
https://www.audiforums.com/forum/gen...6/#post1478675
Thanks in advance guys!
paulywalnuts446
12-22-2018 03:01 AM
Hoguenstein
03-06-2009 12:56 AM
90gli16v
04-09-2006 02:23 PM
Quick Reply: Stuck in Park / EPC / Check Engine
