Sponsored by:
Sponsored by:
Surging on start-up, 4.2 quattro
Old 01-13-2013, 02:19 PM
U's Audi's Avatar
Default Surging on start-up, 4.2 quattro
I've been dealing with this issue for a while now. The first time it happened it threw on the Check Engine light. I used a scanner to read the code (P0101) and it said there was a problem with the Mass Airflow Sensor. I tired using the MAF cleaner but to no avail. I then bought a new sensor from Bosch and installed it 2 days ago. The first start up (engine is cold when this happens) went fine with no surging but when I started my car this morning it surged once again and threw on the Check engine light with the same code. I used the scanner to check if the MAF was reading and it was. I have also noticed that when i add a can of SeaFoam to the gas tank it goes away. Does anyone have any ideas on what could be causing this problem? Thanks.
Old 01-14-2013, 12:01 PM
U's Audi's Avatar
This morning the car started up fine but the check engine light still came on. Would I have to do an ecu reset?
Old 01-24-2013, 09:02 PM
U's Audi's Avatar
The Check Engine light keeps coming on but I've made sure that the Mass Airflow Sensor is working properly. What could be the problem?
Old 01-24-2013, 09:34 PM
01 Avant's Avatar
know anyone with a vagcom? you need to have the readings looked at and also see if the voltage to the sensor is correct in order to diag it further - also check for unmetered air - vacuum leaks or intake tube not sealing correctly.
Old 02-19-2013, 07:17 PM
U's Audi's Avatar
The problem has now gotten worse. The change is that now it will intermittently stall and when I manage to start the engine(usually on the second try) it sounds like the engine is forcing itself. It is also accompanied with a whine. SeaFoam in the tank doesn't seem to work anymore. Every once in a while it does start up fine as well as when the engine is warm. Any further ideas?
Old 02-19-2013, 09:02 PM
retho78's Avatar
Just a guess - probably a vacuum leak or throttle body might be going bad.
Brochacho
04-19-2012 04:55 PM
new2me
11-26-2007 01:22 PM
AudiCross
08-28-2006 03:06 PM
Quick Reply: Surging on start-up, 4.2 quattro
