AudiForums.com
Go Back   AudiForums.com > Audi Models > Audi A6
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Parts Search Today's Posts Mark Forums Read ExperienceGarageUsed CarsVendors TSBs
Search
Welcome to AudiForums.com
Sponsored by Audi USA Parts
Reply
LinkBack Thread Tools Search this Thread
Old 05-02-2011, 12:21 AM
Bklynrx7's Avatar
Points: 4,219, Level: 41
Points: 4,219, Level: 41 Points: 4,219, Level: 41 Points: 4,219, Level: 41
Level up: 35%, 131 Points needed
Level up: 35% Level up: 35% Level up: 35%
Daily Activity: 0%
Daily Activity: 0% Daily Activity: 0% Daily Activity: 0%
Arrow Symptoms of a bad turn signal/ flasher relay
Ive had an ongoing issue with my front signal lights since I got the car. First the bulbs would blow within days of replacement, then rather than blowing they simply stopped working as turn signals, but stayed lit at all other times. The bulb holder themselve both had damage and burn marks, and the drivers side housing is quite damaged but still makes contact with the bulb holder after you play with it a bit. Lately both bulbs will be lit solidly with the lights on but only one will blink when the alarm is armed. Does this look like a relay issue? Thanks in advance for any assistance you guys can provide.
__________________
2000 A6 4.2l
2007 A6 4.2l S-line
Old 05-02-2011, 10:00 PM
Jeffla's Avatar
astrolame
Points: 5,735, Level: 48
Points: 5,735, Level: 48 Points: 5,735, Level: 48 Points: 5,735, Level: 48
Level up: 93%, 15 Points needed
Level up: 93% Level up: 93% Level up: 93%
Daily Activity: 0%
Define damage and burn marks (picture?) Don't be offended, but are you sure you're getting the right bulbs and installing them correctly? I ask because when i think of burn marks, I think of shorting, maybe loose bulbs, moisture, bulb installed backwards or damaged socket. The relay can cause your bulbs to stay illuminated, but I don't know why it would cause the burn marks.
My guess is the bulbs are shorting out, although I'm not sure how that is happening. Somehow the bulbs are being back-fed power causing them to stay on.
It could be you have 2 problems, a bad relay and bad bulb (taillight) clusters. The cluster causing the relay to fail.
__________________
'00 A6 Avant Quat 190k
50% Front 20% rear Tint
Euro Blindspot Mirrors / LED interior lighting
Old 05-08-2011, 12:32 AM
Bklynrx7's Avatar
Daily Activity: 0%
Its fine, but I am definitely installing the right bulbs correctly. The bulbs fit into the socket perfectly but the notches on the socket that interlock with the headlight housing are chipped/bent/damaged/worn ect. The burn marks are on and around the contacts on the bulb socket. Could the tail lights really cause a problem like this? They are working correctly.
__________________
2000 A6 4.2l
2007 A6 4.2l S-line
Old 05-08-2011, 01:30 AM
Jeffla's Avatar
astrolame
Daily Activity: 0%
Ignore my taillight reference, I assumed you were talking about the taillights were burning out. If the connector is getting moisture in it, it will short out and possibly cause the lights to stay illuminated. Get yourself a can do dielectric grease. http://www.acehardware.com/largeImag...-1241343dt.jpg
Fill the connector with the grease and see if it makes any change. You can find dielectric grease at any home store or auto parts store.
http://i61.photobucket.com/albums/h4...r/DSC09293.jpg Maybe not as much grease as this person used, but use a lot.
__________________
Reply
Tags
a6, audi, auto, bad, blinker, flasher, relay, signal, signol, signs, symptom, symptoms, turn, work, wwwgoogleturn
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
New Sponsors
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
SEO by vBSEO ©2010, Crawlability, Inc.
© Internet Brands, Inc.
Emails Backup
