11-30-2004, 12:44 PM
Member
Timing Belt Replacement
I'm getting conflicting info of when to change the timing belt on my 98 A6. I've got 66,000 miles and my mechanic says now, other say 75,000. I have a quote (not Audi dealer) for approx. $800 for the timing belt, serpentine belt, water pump, tensioner, and thermostat. Is this reasonable?
11-30-2004, 12:48 PM
RE: Timing Belt Replacement
sounds resonable...you should change belts around 60,000 even tho the manual and dealers say otherwise.
__________________
11-30-2004, 01:02 PM
6th Gear
Everyone is going to tell you different numbers. The dealer says not until like 110k or something crazy like that. Timing belts (or tensioners or waterpumps, etc. have been known to go as early as 60k miles. This is why people say to play it safe and do it then. A safe range is 60k miles to 75k miles.
Your quote is on the higher side of a private mechanic. I was quoted 600 for the job. The parts are only like 250 bucks, and it shoulnt take more than 6 hours for a mechanic.
__________________
2005 A4 1.8tqm Avant
2004 VW Touareg
2005.5 Audi A4
11-30-2004, 01:16 PM
Member
thanks for the info. is there anything else that SHOULD be changed while i'm having this stuff done?
11-30-2004, 04:05 PM
6th Gear
the Snub mount could probably stand to be changed. They usually start to crack about the same time.
__________________
2004 VW Touareg
2005.5 Audi A4
12-22-2004, 11:00 PM
Factory and engineering (Germany) says A6 timing belts have to be replaced at 75000 miles (120.000km) or earlier...
Unlike many other cars breaking of the belt will cause the engine to be stopped automatically... but you always can be unlucky when the belt snaps and causing other damage...
12-23-2004, 02:19 AM
6th Gear
Any companant in the system can cause the belt to snap too. For instance if the water pumps bearings go out, and causes the belt to jump off.
__________________
2004 VW Touareg
2005.5 Audi A4
12-24-2004, 05:14 PM
That price seems reasonable.
I just spent 3000 repairing my 98 A6 with 71K miles. Got the full 60K maintenance and also got new brakes all belts, water pump, thermostat etc...
Half that was under warranty. Car drives like NEW!
Too bad I just got a company car (Grand prix) so the audi will not be used as much. Wife wants me to get rid of it, but it aint gonna happen!
02-03-2005, 12:24 PM
I'm having my water pump and timing belt replaced today on my 2000 A6 2.8L. It's costing me $857 at the local Audi Dealer. Seems high to me but I've got no choice. Car just passed 50K. Dealer told me the water pump was bad and so it's a good idea to change the timing belt now too since it probably got wet. Just two weeks ago the car was in for a brake fluid change and they changed the serpentine belt then. Wish they had noticed the water problem then.
02-04-2005, 09:02 PM
Just had my timing belt & water pump changed last week here in the UK, at a local Audi dealer. The price was £650, which translates , at the current $/£ rate to about $1100!!. Sounds steep I know but I looked around at independent dealers and VW main agents (as they can do the work too) and the Audi dealer came out best for price. Naturally I got a free loan car too and great service and it was peace of mind as it was all main agent guaranteed.
This was particularly relevant as the day after the job, the engine started cutting out, especially when cold and the timing seemed slightly out. The engine noise was also louder than normal. I took it back to Audi and they diagnosed a fault with the new belt tensioner they had just replaced. This meant they had to do the whole timing belt replacement again, which they quickly did with apologies all round from them because of the faulty item. After this experience I would definitely return to the Audi main dealer for any similar major repair work, as it pays in the long run.
Incidentaly the A6 is a 2002 Diesel 2.5 TDI Sport...with the belt/pump changed at 91,000 miles (the book suggests 80K)
now runs as new and will go for another 100K!!
(Nice forum by the way)
Tags
2004, 2005, 20055, a4, a6, audi, auid, belt, change, cost, pump, replacement, timing, touareg, vw, water  |
| Thread Tools |
Search this Thread |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
