Sponsored by:
Sponsored by:
Transmission Fluid Filler location
Old 09-11-2010, 06:37 PM
michaelh305's Avatar
Exclamation Transmission Fluid Filler location
I have an 2000 Audi A6 2.7t And I was wondering if any one has a pic of the location of the ATF filler location or can go in depth about where to find.
Thanks in advance
Old 09-11-2010, 06:48 PM
TwinTurboC5's Avatar
Default Transmission Fill Plug
Hi. I don't have a pic, but will try my best to desribe where the fill plug is located. If you look under the car at the transmission pan, you will see two plugs on the bottom of it. The plug farthest foward (near the engine) is the drain plug, and the plug farthest to the rear (near the Diff) is your full plug. If you're still not sure...the fill plug will be the plug that is the largest in diameter. Hope this helps.
Old 09-12-2010, 09:39 AM
NH_USA's Avatar
I am not sure about your 2000 2.7t but if it was a 2.8 you can't just fill the trans and set the level with a stick.
On the 2.8 you need to jack the vehicle up -keeping it level - run the motor until the trans is at a specified temp as indicated on VagCom - and fill the trans until the fluid drips out of the top hole.
There are numerous discussions with details on this board - just do a search
Old 09-12-2010, 10:09 AM
nemohm's Avatar
ATF filter (as on most cars) is located in the transmission oil pan. The filter is attached to the valve body.The access is only after taking off the pan. Most filter kits come with transmission oil pan seal which should replace the old one. Look for the torque sequence and rates.
Old 09-12-2010, 04:30 PM
NH_USA's Avatar
nemohn --Ya need to get new glasses or increase the font size on your computer screen
He said F I L L E R not F I L T E R.
Old 09-12-2010, 05:52 PM
NorthD's Avatar
Default this will help
Thanks in advance
http://forums.vwvortex.com/showthread.php?1093467
this will help although pics are gone but good references
Old 09-12-2010, 05:56 PM
ratherb1's Avatar
pita but a diy just be very careful, is there a problem you are having? is any signs of tc failure slipping, jerking, codes ect... i wouldnt touch it if not but thats my opinion
Old 09-12-2010, 10:29 PM
Jackmup's Avatar
located on the pan looks like the drain plug but is recessed up into the pan- center rear of the pan.
The car needs to be running and at specific temp rasnges to fill it correctly. The only way to do it right is with a vagcom monitoring the temperature, A gravity feed Transmission fluid filler- not the pump and the car running on jack stands with two people. one filling the other shifting and watching the vagcom.
It's a friggin nightmare the first time but once you get the hang of it you'll think of it more as another Audi pita.
Old 09-13-2010, 03:11 PM
nemohm's Avatar
Yes Sir,
""nemohn --Ya need to get new glasses or increase the font size on your computer screen
He said F I L L E R not F I L T E R.""
Yes Sir,
New glasses are ordered. Waiting for delivery
(no kidding at all - you've got the situation perfectly correct).
Sorry for the filter...
Old 09-14-2010, 01:49 PM
NorthD's Avatar
Default very good thread
http://www.audizine.com/forum/showth...-Automatic-Tip
looks very good
L8R..........
Quick Reply: Transmission Fluid Filler location
