Trying to Replace the Hazard Relay
I am trying to replace my hazard relay, but the problem is, I can't seem to take out the relay. I'm reading all the guides online and they make it seem so easy. I've tried pulling the hazard relay with enough force to the point I don't break anything and I only end up taking out the red plastic triangle instead of the relay. Any pictures, tips, and suggestions on how to take this out?
Thank you!
edit: The car is a 2002 Audi A6 2.7T Quattro
Thank you!
I did this last summer, so I had to look at a picture of the relay to remember how to do it.
You have to use two small flat head screw drivers on either side of the relay to press the two metal locking pins in. After they are pressed in, you can use the screw drivers and your hands to pull out the entire black piece that houses the relay and light. Once you get that out, it IS a rather simple job compared to most stuff on our cars.
