Sponsored by:
Sponsored by:
unknown warning symbol?
Old 04-13-2011, 10:49 AM
epidemik11's Avatar
Default unknown warning symbol?
I have a 2002 A6 3.0 that I purchased in December. I have brought the vehicle back to the dealer for an ongoing warning that turned out to be the torque converter. The dealer held the car for a month, and I finally got it back yesterday. Upon driving, a new warning appeared in my information area. The symbol is one that I cannot find in the manual. It is an encircled exclamation point that looks like a tire warning. The difference is to the left of it are 2 arrows, one up and one down, with 3 waved horizontal lines in between. Does anyone know what this means? Thanks a lot.
Edit/Delete Message
Old 04-13-2011, 11:01 AM
rflaig's Avatar
perhaps a water pump or coolant system?
Old 04-13-2011, 05:17 PM
ppgoal's Avatar
That is your dynamic headlight control warning. There is a sensor behind the left headlight and one in the right rear quarterpanel (or so I've been told) that control the headlight alignment. I was not even aware that my A6 had this or that it worked, but I lived with the icon for a couple months until someone on audizine told me to pull fuse 10. You might do a search here on "dynamic headlight" and you'll find some discussion.
Old 04-13-2011, 05:44 PM
epidemik11's Avatar
Thank you. Does pulling the fuse reset it, or does it just get rid of the warning?
Old 04-14-2011, 01:36 PM
ppgoal's Avatar
Best that we could determine, the front sensor had failed. The sensor itself is not replaceable -- you have to replace the whole headlight assembly and that was cost-prohibitive. Since the warning icon was driving me nuts, pulling the fuse just powered off the sensor and icon. It did not reset or fix it to the best of my knowledge, but I never replaced the fuse.
Old 04-14-2011, 03:39 PM
epidemik11's Avatar
Ok, thank you very much. I guess the dealer will be seeing the car again in the very near future.
Old 04-14-2011, 05:31 PM
bob martin's Avatar
The sensors are on the control arms.
Pull fuse #10 and the system goes away as far as the car is concerned. You might have to manually adjust your headlights but then you will be good to go.
Bob
Old 02-12-2012, 12:17 AM
deanahamilton's Avatar
Smile
Bob
thankyou pulling fuse worked got rid of error light in car
Old 07-13-2012, 12:58 AM
muratuncu's Avatar
Default Same symbol and more...
Hello all,
I was just searching for the same symbol you just described, and I am happy that it is not a major issue.
However, I do have another symbol which is the min. oil level indicator. It has been on on the 2ND day of my purchase. Fortunately, I do have a warranty for my 03 A4 3.0 for 12 months, and I will go see the dealer tomorrow, because they just changed the oil when i was waiting to hop in to my car(I assume they did).
My question is is it very likely to have an oil leak? I have never had any issue about leakage on my cars so far, and it concerns me a little bit.
Old 07-13-2012, 05:00 PM
ppgoal's Avatar
My daughter has the exact same car (with 95k miles) and during a 500 mile drive in 90o weather, including long border waits, the same icon went on. She found her oil was below the minimum line and topped it up. She's had the car 4 years (since 69k) and it never burned or leaked oil. Not sure if this was due to hot weather. If your car has the drip shield under the engine, it will catch any leaks. If you are suspicious, remove the shield and place newspaper underneath the engine. Or let your dealer figure it out. It could be a failing oil sensor.
anirafac
06-25-2014 10:52 AM
csaylor09
05-02-2013 01:58 PM
TomKat
03-23-2013 09:11 PM
audib598
06-17-2012 08:25 PM
epidemik11
04-12-2011 07:05 PM
Quick Reply: unknown warning symbol?
