06-11-2007, 02:02 AM
VIbrating Steering wheel at high speeds
Hi, I have this problem where my steering wheel starts to vibrate very violently when I exceed 65 mph on the highway. When I go down in speed, the vibrating stops again
Any idea what could be the problem?
Also, sometimes when I turn the steering wheel there is a whining sound, like the power steering is struggling to work. Any ideas on how I can fix this as well?
1 other small problem, the suspension feels like it is very bouncy, sometimes when I go over bumps, the car boucnes up and down 3-4 times before coming to a halt. DO I ened new shocks or new springs?
Let me know, thanks in advance
06-11-2007, 10:45 AM
Level up: 93%, 15 Points needed |
RE: VIbrating Steering wheel at high speeds
How many miles are on your car? Sounds to me like you need new shocks. You also need to have your tires balanced. Check the fluid level of your ps fluid(uses special fluid of course), but ps pumps do slightly whine.
__________________
'00 A6 Avant Quat 190k
50% Front 20% rear Tint
Euro Blindspot Mirrors / LED interior lighting
06-11-2007, 10:51 AM
Level up: 50%, 100 Points needed |
Quote:
ORIGINAL: Jeffla
Ditto!
OOOO
__________________
Spec Stage II Clutch and Aluminum Flywheel, APR Software, APR Snub Mount, APR Downpipes and Test Pipes with Milltek Cat Back, Hyperboost Diverter Valves, K&N Drop In (Temp).
06-11-2007, 12:29 PM
Level up: 49%, 103 Points needed |
The standard test for worn shocks used to be pushing down hard on each corner of the car. If it bounced even oncerather than returning to normal height, then your shocks need replacement.
Any steering problems at speed are probably due to one or more wheels out of balance. But you could also have an alignment problem causing uneven wear which could contribute. If you haven't ever checked, have the car aligned and then the wheels speed balanced. I aligned my car in at 96k because my Coopers were cupping slightly and the alignment was toed in just enough to cause the problem.
Also, rotate your tires (front to rear) regularly.
Agree with Joeski on the P/S. There is often a slight whine from the various spinning components. If you notice P/S fluid leakingor disappearingor it gets real difficult to turn, then you knowthe unitis failing. You can drive it without P/S, but it will build up your arm muscles quickly.
__________________
2003 A6 2.7T MT6
Premium-Cold Weather-Bose; GIAC-Bailey DVs-Samco TBB-K&N
AWE Stage 2 Clutch+Lightweight Flywheel; Colgan Bra
Billy Boat Downpipe Kit; SS Brakelines
235/40 ZR18 ContiExtremeContact; Velocity RS4 Replica Rims
06-11-2007, 04:21 PM
dido...also check your ball joints and your wheel bearing to be on the safe side
__________________
Envied A6 - 2001 Silver Audi A6 2.7T Tiptronic, InMotion Stage 2 chip, Blitz custom intake, Dynomax Turbo custom exhaust, Custom down pipes, Turbosmart MBC, CF interior trim, arm rest, engine cover, air box cover, hood,trunk, mirrors, B pillars, eyebrows, H&R springs, H&R 5mm and 10mm wheel spacers, 19x9 Konig Next rims
06-11-2007, 11:18 PM
Level up: 94%, 12 Points needed |
I Have 99 A6 and the same thing happened- The inner front tires wore down to the steel belt-Take the tires off and check them out- I replaced tires and got an alignment- Runs great now.Get your alignment done by a quality shop that has worked on Audi's-
06-12-2007, 09:51 AM
check tire balance if no then its the servotronic steering. mine does that. push it towards 100 and it goes away. it only does it in a window, not below or above
__________________
  dont kill me
Tags
03, 06, 2001, 99, a6, audi, high, shaking, shaky, speed, speeds, steering, vibrates, vibrating, wheel  |
| Thread Tools |
Search this Thread |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
