Sponsored by:
Sponsored by:
What size spacers do I need for my car?
Old 03-09-2008, 10:08 PM
formulagigi's Avatar
Default RE: What size spacers do I need for my car?
235 = Width of tire in mm
40 = tire wall ratio
18 = rim diameter
When you plus size your rims, you should typically kep the width identical, lower the tire wall ratio (45 to 40 for 18" rims, or 35 for 19") to make up for the larger rim size. Overall diameter and Revolution Per Mile should remain close as you plus size. Discount Tire has a good tire calculator.
If you kept rim size identical (ie 17) but wanted to get a wider tire, you would need to decrease the second # (tire wall ratio) as well. I did that on my Fiat a long time ago.
Old 03-09-2008, 10:40 PM
trapped's Avatar
Ok so for example the velocity Rs4's are 8.5 across, and the DTM's are 8, would the 235 work on both of thoes?
Old 08-26-2014, 07:14 AM
bau2.7's Avatar
Default 2004 A6 S-line, is anyone running 245/40 R 18 ??
was anyone able to run 245 on their A6?
euroimport88
02-28-2011 10:56 PM
jaymac
04-26-2009 11:04 AM
pa4ul
09-29-2008 10:36 AM
avantgradeA6
01-10-2008 05:01 PM
Quick Reply: What size spacers do I need for my car?
