Sponsored by:
Sponsored by:
wierd vibration/misfire 2003 a6 4.2
Old 10-23-2007, 03:36 PM
mtrain's Avatar
Default wierd vibration/misfire 2003 a6 4.2
I have a 2003 a6 4.2 with a vibration/misfire that my mechanic just can't figure out so i thought I would post it here to sdee if anybody has any ideas or a similar problem. The car runs great when you drive around town but in 4th gear or 5th gear there is a wierd vibration right at 2000 rpm which goes away as soon as the car downshifts. I would think it was something in the driveline if it wasnt for the engine light flashing and also it seems to be RPM dependant not road speed dependant. Also, if you accelerate really hard on a freeway on ramp the car starts to surge and buck at higher rpms and the engine light flashes. My mechanic replaced the coils, MAF, seconday air pump, which were all things coming up in the fault codes but it still has the problem and still has the random misfire fault code. Any ideas?
Old 11-24-2013, 12:08 AM
guru KA9's Avatar
Default try to ask for icm...
in regards to your issue i have discussed this with my mechanic he says to order a new ignition control module, i will be replacing mine i'll hit u back in the spring it's a very likely fix without even seeing your car, ask around i'm sure youle find this helpful as i know my engine is tip top yet a simple fault in this module will throw false code all day your way
Old 11-24-2013, 04:23 AM
M5S5's Avatar
Tech Certified
I would get a fuel pressure gauge connected & see what the fuel pressure is doing under heavy load.
KoolMan
07-19-2012 02:38 PM
Derrickpike
07-18-2010 12:22 PM
buckeye96
B8 Models
54
11-05-2009 07:48 AM
Caylin
05-12-2005 09:02 AM
millsi
03-04-2005 01:08 AM
Quick Reply: wierd vibration/misfire 2003 a6 4.2
