2003 A8 PCV questions
Old 04-20-2014, 09:53 PM
dave944's Avatar
Default 2003 A8 PCV questions
I'm getting a lean error code on my A8 and suspect the PCV valve. After a bit of Googling and Youtubing, I need to get some things clarified.
True or False: If, when the engine if running at idle, you remove the oil filler cap and you fell suction holding the cap on to the opening, the PCV is bad?
Also, when the engine is running and you hold your finger over the opening at the top of the PCV valve, I can put my finger over the opening and feel suction. Pretty strong suction. Does this mean the diaphram inside has a hole in it.
I did find one source of the air leak which turned out to be the hose from the secondary air pump where it connects to the stainless steel tubing at the valves at the back of the engine. Deteriorated and cracked right at the clamp. Was able to snip a bit off and reconnect. Still need to replace the thing but it can wait.
Anyway, can I get a definitive answer on the PCV Valve?
Thanks,
Dave
Old 04-21-2014, 10:53 AM
dave944's Avatar
Just saw a post below that confirms my suspicion of the leaking PVC valve. If you can feel a suction (I cannot hear it because I'm about flippin' deaf anymore) in that little opening on the top of it, it is sucking excess air and is causing a lean error. It's also tripping a MAF sensor error (new MAF thrown at it).
Now if I can just find that EVAP leak, I'll have this puppy licked for a while.
Thanks,
Dave
Old 04-25-2014, 04:16 AM
ivanvag's Avatar
Just replace it, AUDI recommends replacing it on 60 000 km
Old 04-28-2014, 09:03 AM
dave944's Avatar
Got a new one on the way. This one is probably original. Car has 160K miles on it now.
davidsziegenfuss
01-10-2020 05:57 PM
ppgoal
08-18-2007 04:41 PM
flipkid
05-29-2007 11:01 PM
RyuukoGo
04-25-2007 04:57 AM
rexrex
12-05-2005 02:22 PM
Quick Reply: 2003 A8 PCV questions
