help needed - unbolting gearbox
Old 11-09-2010, 12:29 AM
340i's Avatar
Default help needed - unbolting gearbox
Hi,
Hopefully someone can help me with a problem I have...
I have removed the v8 and quattro box from my 96 A8 and unbolted all the bellhousing bolts but the gearbox wont come off. Is there some trick to it or is it just stuck and needs a good handfull of leverage applied to it?
Tips much appreciated
Old 11-09-2010, 08:42 AM
silverd2's Avatar
Have you removed the starter & unbolted the TC from the drive plate?
Old 11-10-2010, 01:23 AM
340i's Avatar
no i havent done that, ill give it a go. i hear i might need to unbolt the torque converter but i didnt know how to access it. thanks
Old 11-10-2010, 08:48 AM
silverd2's Avatar
Should be 3 bolts...turn engine 1/3 rev at crank pulley (T-belt installed!) to access each through starter 'hole'.
Old 11-11-2010, 09:50 PM
aspen79's Avatar
Even with ALL the fasteners off, they sometimes are still stuck from corrosion to the alignment pins (steel pins into aluminum housing).
cjfoley1985
05-06-2015 07:41 PM
Theradlettfineart
10-15-2013 05:35 PM
thenjd
01-23-2008 04:00 AM
antoncole
10-03-2006 05:11 PM
Quick Reply: help needed - unbolting gearbox
