Audi Q7 The Audi Q7, beauty on and off the streets. Refined styling paired with power and advanced technology.
2009 Audi Q7 4L 3.0 TDI cranks but doesn't start
Old 03-14-2017, 01:15 PM
harish.krovvidi's Avatar
Default 2009 Audi Q7 4L 3.0 TDI cranks but doesn't start
Recently picked up Q7 3.0TDI with 75k kms on the clock. It has an ABS and ESP error that piped up soon after tire rotation and alignment work being done.
Saturday last week,, while I was overtaking at about 80/90kms speed the car just died. It cranks but doesn't start ever since.
I don't have a VAGCOM but I did scan using Launch X431. Below are the error codes. The scan says there are 8 errors in total
008213 - intake manifold flap position sensor bank 1
000135 - fuel rail / system preasure
05405 - ( 24, F1, 15, 1D) please refer to relevant tech manual
001393 - break switch (F)
01423 - sensor for leaking lateral acc.-G200
01487 - system function test - value of resistance too great
01486 - system function test activated
00778 - steering angle sender G85
from google, I understand that none of these should have lead to the car stalling while driving.
have any of you experienced similar issues, should I be checking the crank position sensor. I see that the RPM needle move while cranking. Does this me an that the CP sensor is working.
Old 03-19-2017, 12:45 AM
Have done the following
1) removed the bank 1 and 2 to clean and re fix the swirl flaps. Bank 1 has play so am using a rebuild kit to fix both the banks.
2) cleaning the intake manifold, EGR and throttle body
Hope the clean and refit plus the siwrl flap kits fix the issues.
Old 03-21-2017, 01:16 AM
Completed clean and refit. Battery went dead so I will charger and then try cranking
1) clear all error codes
2) use freshly charged battery
Will post progress later today
Old 03-21-2017, 02:00 AM
Got a spare battery and the car still won't start. Any one help !!
Old 03-24-2017, 09:01 AM
Audi dealership called today said that they found metal shavings in the file filter and may need to change he fuel delivery shatter in the car.
Not sure what all needs change based on this.
Old 05-08-2018, 10:32 PM
2007AudiQ7's Avatar
Hi Harish - Can you tell us how this ended up? My 2007 Q7 won't start, no 'priority 1' codes, seems to have fuel pressure, new battery, fully charged.
Thanks in advance
Old 05-08-2018, 11:33 PM
Thanks in advance
Fuel pump was toast.
Open the engine cover
look for the fuel mechanical high pressure fuel pump
there is a fuel metering sensor on its right side
remove the sensor. Check for metal particles. If found then that is the reason the car is not starting.
you will see error codes for fuel pressure
Old 05-21-2018, 08:42 PM
2007AudiQ7's Avatar
thank you
aRIf
12-16-2021 12:48 AM
JDF
04-12-2012 01:58 PM
Billydakid
10-29-2010 02:40 AM
PCdude4583
04-12-2008 11:28 PM
Quick Reply: 2009 Audi Q7 4L 3.0 TDI cranks but doesn't start
