Audi Q7 The Audi Q7, beauty on and off the streets. Refined styling paired with power and advanced technology.
Help, doors dont unlock
Old 04-22-2014, 06:32 PM
PuffDiddy01's Avatar
Default Help, doors dont unlock
Soo... I have a 2007 Q7. I think My Audis battery is dead. I cannot unlock it from the remote, and if I put the key in the lock, it won't turn either way. I want to jump start it. But I can't get in the car to open the hood. If there is a way to open the hood without getting in the car or if anyone knows how I can open the doors, it would be greatly appreciated.
Old 04-23-2014, 06:49 PM
aspen79's Avatar
It's all but impossible to open the hood from outside the vehicle. You need to go up from under the front end and find the lever the cable attaches to and pry it to the left. Requires very long skinny arms (just kidding) or a long thin prybar or similar thing to do. It may not be possible to get anywhere near the hood latch though.
The lock cylinder is probably corroded solid from never being used. Try spraying some penetrant into the lock. You need a straw on the can, push the straw in to move the shutter out of the way. Use a GOOD penetrant. WD-40 probably won't do it (not a cut on WD-40 btw). Keep working the key in and out and try turning both ways but don't force it too much. If the key starts to twist, STOP. It might take a while and be really tedious but most times they'll eventually loosen up enough to work.
One idea that might work. If you can get to the starter motor solenoid (on the starter), you could clamp a jumper cable onto the upper large terminal and hook the negative cable to a good ground point under the vehicle. That should in theory power it up so you can use the FOB to unlock the doors.
Old 04-24-2014, 02:47 PM
Thank you soo much for replying! I'm not sure what you mean by "penetrant", I had some WD-40 Laying around and it didn't work with that. Can you please tell me what penetrant is.
Old 04-24-2014, 07:05 PM
aspen79's Avatar
Oh sorry, what I meant by penetrant was rust penetrating oil. A couple brands are "Liquid Wrench" (not that good really), "PB Blaster" (better) and my favorite "Aero Kroil". Out of the 3, Aero Kroil is the best penetrant I've ever used. It's not cheap (like $20 a can) but it's worth every penny.
I was going to post pictures of the cans but my internet is giving me fits.
There's always the chance that the problem is in the latch itself. The lever the lock cylinder link attaches to could be seized. It's rare for that to happen though. Not sure where you live but it'd be more likely in one of the "salt states" like Wisconsin, Minnesota, Michigan, NY, etc.
Good luck, hope you get it to work.
Old 04-25-2014, 06:16 PM
Which store can I buy one of those from?(btw I live in Canada and the month I didn't start the car, the weathers average was -13 Fahrenheit) this happened before I was gone in the summer and didn't start it but that time the car unlocked by itself before the battery died. Thank you so much for your help!
I was wondering, I could call a tow truck but he would probably take around $120.
A4driver17
04-22-2015 03:05 PM
MJHay
06-10-2012 09:28 AM
kiwiaudi
08-30-2011 12:17 PM
afstud6900
12-17-2008 03:22 AM
Quick Reply: Help, doors dont unlock
