01 TT with a cylinder 3 misfire
It has a miss and I changed the coil pack cause I know those go bad a lot on these cars. It didn't fix the problem and now I'm not sure what the problem is. I heard it could be a wiring harness issue or ECU issue. Any ideas?
I've got misfires across the board. im in the process of replacing alot of things. I've replaces plugs and im waiting on coils, and the wiring harness for the ignition coils. I've also cleaned my maf. It's running withing normal range on vag-com so i'd going to say its fine. Im also replacing both knock sensors. Ill let you know if this works. So far changing the spark plugs didnt do anything.
I have changed
-spark plugs
-ignition coils
-fuel filter
-maf
-cleaned throttle body
check your injector dude ...and where did u get ur spark plugs from ....my timing belt went i changed everything and new spark plugs and after like 500 miles on the new head and spark plugs it started missfiring bad ...find out 2 sprk plugs died and bad 3rd injector ...i had to get spark plugs from audi dealer thats the only one that it can would handle
good luck bro
good luck bro
good luck bro
good luck bro
Russ Heinrichs
08-18-2021 12:39 PM
A4ENGRSF
10-09-2010 09:49 PM
