01 TT overheating only at idle - AudiForums.com
Reply
LinkBack Thread Tools Search this Thread
Old 07-28-2010, 10:00 PM
Default 01 TT overheating only at idle
I've got this problem, I've seen several threads with problems that were pretty similar...but none that are the same.
When I first start the car, the coolant light flashes on and off for 1 minute and beeps several times. After that 1 minute it's never on anymore.
While driving the car is fine, but when I'm idling at a stop light or anything to that effect the gauge rises up to about 3/4 of the way to max. When I start driving again, the temp gauge slowly moves its way back to 1/2 way. The A/C has little to no effect on whether it overheats or not.
When I shut off the car earlier I heard bubbling, and saw the coolant in the overfill was bubbling. I slowly opened it up to let it vent out. (not sure if I should of or not) So now the coolant level is at the bottom of the overfill reservoir.
The thermostat and coolant temp sensor were both changed about 2 years ago. Although I'd like to do the work myself now as the prices were pretty outrageous for that. If anyone can point me in the general direction for a diagram of an 01 TT so I could do the maintenance myself I'd greatly appreciate that as well.
Any help will be greatly appreciated!
Old 07-29-2010, 12:03 PM
Get a Bentley manual......paper copy or CD. Paper is an easier use.
Peruse sites like:
http://www.wak-tt.com/
that have a lot of the answers.
"coolant light flashes on and off for 1 minute """""
indicates low coolant level.
""""the temp gauge slowly moves its way back to 1/2 way."""
do you have the original water pump? Broken impeller(s)? Fans cycling correctly?
""""""and saw the coolant in the overfill was bubbling.""""
You need to use the HVAC control to monitor temp and go from there.
Reply
Thread Thread Starter Forum Replies Last Post
Audi A4 B5 Throttle Alignment Problem, Not Aligning, Rough Idle, Hunting Idle justinclarke B5 Models 3 11-26-2010 03:29 PM
Audi A4 B5 Throttle Body Alignment Problem, Not Aligning, Rough Idle, Hunting Idle justinclarke DIY - Do It Yourself 0 11-25-2010 05:03 PM
Coolant light on start and overheating at idle CMaddox General Tech 0 07-28-2010 10:11 PM
Idle hunts & whissle @ idle. Mean buzzen half dozen 08 A4 B7 Models 7 01-06-2010 12:36 AM
overheating myslow1 Audi TT 10 04-18-2009 10:35 PM
Tags
2000, a4, ac, audi, bubbling, car, coolant, gauge, heard, idle, idling, low, overheat, overheating, overheats, slowly, temperature, tt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
