2000 Audi TT Possible Piston Rings Problems
I have a 2000 Audi TT Turbo. I recently replaced my head gaskets & had the cylinder head rebuilt. After i installed the cylinder head the car drove fine for about 1 day. After a week of having this done the car started to smoke out of the tail pipe. The smoke smells like oil & oil drips out of the exhaust. It smokes & drips a lot of oil from the exhaust. Im thinking that the piston rings are worn or broken. I did a compression test with the engine cold & these were my results:
Dry Test
Cylinder 1- 90 PSI
Cylinder 2- 85 PSI
Cylinder 3- 80 PSI
Cylinder 4- 82 PSI
Wet Test
Cylinder 1- 105 PSI
Cylinder 2- 110 PSI
Cylinder 3- 110 PSI
Cylinder 4- 105 PSI
What do you all think? Any suggestions are greatly appreciated.
Dry Test
Cylinder 1- 90 PSI
Cylinder 2- 85 PSI
Cylinder 3- 80 PSI
Cylinder 4- 82 PSI
Wet Test
Cylinder 1- 105 PSI
Cylinder 2- 110 PSI
Cylinder 3- 110 PSI
Cylinder 4- 105 PSI
The engine has to be at temp for the numbers to mean anything. 120 is the min and all of them need to be within 10% from high to low.
You did use new head bolts correct as the stocks are not reusable?
