Break lights NOT turning off!
20 mins ago i got to class, turned off the car, turned off the headlights, and saw that my break lights were still on. Tried a number of different combinations of fliping the lights on then off, then turning off the car..Still, break lights on.
Got home, pulled out the fuse and lights turned off-put the fuse back in, brake lights came right back on.
Checked the brake pedal and it seems normal.
Any idears>>>
Any idears>>>
brake light relay switch. you need to go under the dash and unplug them before ur battery dies.
a new switch was like 20 bucks i think and it was an easy install. it rotates and pulls out and the new one goes back in the same way. there is also a clutch relay switch down there too.
i had the same problem, but i came out after 8 hrs of work and my battery was dead. (i couldnt see the lights on in the direct sunlight)
chesterfan1230
04-17-2011 06:41 PM
