CEL - Pulled Code P3081
Old 08-22-2007, 11:00 PM
munkee's Avatar
Default CEL - Pulled Code P3081
Knowledge me please.
Thanks!
Old 08-22-2007, 11:33 PM
munkee's Avatar
Default RE: CEL - Pulled Code P3081
after doing about 30seconds of Google research, I come up with MAF Sensor...
does anyone agree?
Old 08-23-2007, 12:41 AM
p1zl3's Avatar
19537 4C51; P3081[/b] - Engine temperature too low
Check for a missing thermostat, a stuck thermostat, or a cooling system that's all antifreeze. You might need to replace your coolant sensor also ($10)
Hope that helps!
Old 08-23-2007, 12:46 AM
p1zl3's Avatar
BTW, go with the green-top sensor. They fail far less than the stock ones...
Old 08-23-2007, 01:50 AM
munkee's Avatar
Is this an OEM part or can I pick it up from AutoZone?
AUUUUUTOOOOO ZONE! (commercial voice sound)
Old 08-23-2007, 02:29 AM
p1zl3's Avatar
ORIGINAL: munkee
Not sure... AutoZone has this incredible knack for acquireing random-*** parts at cheap prices. You should certainly try there first before financially "grabbing your ankles" at the dealership...
...they don't call it a "stealership" for no reason...
Dealership=[sm=lildevil.gif] AutoZone=[sm=grinangel.gif]
Goodluck Bro!
Old 08-23-2007, 03:30 AM
P3081 dosnt appear on my list of codes and coolant temp sensor mainly starts at P12**, very strange code??
Old 08-23-2007, 03:41 AM
it seems to be a code with many meanings and asked on many sites so ill look into it,
http://forums.vwvortex.com/zerothread?id=1506656
http://forums.vwvortex.com/zerothread?id=2570430
edit:
Sample Answer below :
VW Jetta GLI/VR6, 2003
The error code, "P3081" has been identified from a recent diagnostic and I was wondering if you could be so kind as to help me interpret what this code is and how, perhaps, to remedy this problem..if any...
"19537 4C51 P3081 Engine temperature too low"
That DTC is indicative of a missing thermostat, a stuck open thermostat, or a cooling system with 100% antifreeze. It is NOT associated with a defective ECT G62.
[align=left]
[blockquote]
When the coolant temperature is too low, that does not necessarily mean a sensor failure. Sounds like the sensor is telling you the truth.
Watch the temperature on the scan tool as the engine warms up. Look for things that keep it from warming up. Things like radiator fans on all the time, straight anti-freeze, stuck open thermostat and so on. That is what it means. It means a system problem, not necessarily a component failure.
http://www.freeautomechanic.com/checkenginelight.html[/blockquote][/align][/align]
Old 08-23-2007, 08:46 PM
p1zl3's Avatar
That's the same diagnosis listed above...but thanks for re-affirming things.[8D]
deem2000
01-22-2012 01:23 PM
sdboarder84
02-23-2008 11:04 AM
LouMan
11-08-2006 09:02 PM
A4speed
10-24-2006 05:38 AM
tdctt
10-26-2005 04:23 AM
Quick Reply: CEL - Pulled Code P3081
