Engine Temperature/ Transmission Shifting issue
I replaced all parts related to overheating a few times. I think it may be the fault of bad aftermarket parts.. Who knows. The last fix that fixed it was the Fan Control Module. Could also be the fan switch in the radiator, or the fans themselves. FCM and switch are pretty cheap fixes.
Where is the fan control module located? How to check if it is bad or if the fan itself is bad. Thanks.
the fcm is underneath the battery box. i would put 12v on the connection to the large fan disconnected from the fcm harness and directly from your battery or a 12v DC source to test.
mine was blown so i bought a Dorman replacement fan shroud assembly from autozone and fans work properly. Unfortunately, i believe it is my waterpump that is bad. i'm still in the midst of changing that out and i'm working 2 jobs so i haven't had much time to work on the car.
Looks like the upper radiator hose is in the way, does this have to be removed?
Thanks for your help.
Can you please briefly explain how one removes the fan. Looks like the fan shroud is fixed with 4 screws, the uppers one are accessible from the top but the lower ones can only be accessed from the bottom?
tom
