04-20-2009, 06:32 PM
Fan relay problem?
Hi guys,
need your help here.
My A/C is not pushing cold air and my car overheats if it does not move after a while. With the So Cal weather getting hotter I need to get this resolved asap.(it hit 101 degrees yesterday and today)
My conclusion is that the fans are not working for some reason.
1) Where is the fan relay located? Does VAG detect relay problems?
2) Is there a DYI for freon refill?
Thank you all, much appreciated.
04-21-2009, 03:18 PM
Hey azn..I've been dealing with the same problem since last summer..It's your Fan control module located underneath the batter..Thing is though..I've replaced my module 3 times now. Either I bought crap modules, fans are pulling to many amps, or the fan motors themselfs are shot...Now i've troubleshooted everything i possibly could have..the radiator fans dont run on a fuse themselves. The module is what gives them power.These modules are pretty easy to replace.. it's a little rectangular box. When you take out your battery, take out everything that the battery is connected to etc. the module is under the metal wall the battery sits on and there are two screws holding it in. I'd suggest purchasing your module from germanparts.com the part number is
1J0919506K it's like 115 bucks. Now if you have the same problem as i do, then I would suggest having someone check to see if your radiator fans are actually working and not pulling to many amps.. otherwise you could possbily short out your new module.
p.s. shut your car off when sitting and take routes you know aere that busy..don't want to **** anything up..Audi tech told me not to even drive my car but screw that.
__________________
2001 Audi TT 225, even the M.I.L.F.S Wink and Wave!
04-23-2009, 08:24 PM
Level up: 10%, 181 Points needed |
did you check the fuses on top of the battery?
04-28-2009, 02:02 AM
I did, idk if azn did tho..
__________________
05-20-2009, 11:13 AM
Yah man thanks guys!
I finally had the chance to take a look at this. I found the fuse on top of the battery burnt out. I replaced all 3 fuses with better quality ones; the AC+fans came back online!
I did buy the relay however but I guess I will hold on to it till it fails...
THANKS A MILLION!
05-20-2009, 03:47 PM
Wish mine was that easy.. i"m still having problems heh..Put the new module in and the fans are still out..Good news is the ac and the auxilary water pump are working again.
__________________
06-12-2009, 02:56 PM
Same TT problem
My 2001 TT is doing the same thing A/C and rad fan not working - Changed thermoswitch and relay module - still not working. No power to Thermoswitch but power after we changed the module but then imediatealy after power to switch stopped when A/C turned on.
Help!!!
06-12-2009, 10:31 PM
Level up: 11%, 178 Points needed |
Same thing happened to my car.
The fan switch unit was fine, but the actual driver's side fan was busted.
__________________
06-15-2009, 03:57 PM
My Main Coolant Fan isn't working anymore. I will check the fuses and see if that helps. Otherwise should I get a new fan or a relay first. Those things aren't cheap and I hate to replace both if I don't have to. My Temp gauge is passing the middle mark and that's the only reason I checked the fan. The secondary fan is working but the primary isn't.
__________________
'04 BR Audi TT 225, 42DD DP, BlueFlame Catback, Revo Stage2, MOFO, Modshack BoostMachine, 4bar FPR, Forge Splitter DV, BPi Flowstack with AEM Dryflow 5" Filter, DS Shortshifter, Koni FSD with Eibach Pro Kit, Neuspeed 19mm Rear Swaybar, LiquidTT
06-25-2009, 06:30 PM
Member
are the fuses located with the rest of the fuses? what is the "black box" with wires that sits on top of the battery?
i haven't seen my drivers side fan run even with the temp gauge 3/4 of the way to H. i would like to check the fuses before i take it to be diagnosed but i don't know were they are.
Tags
1j0919506k, 2001, a4, a6, ac, audi, control, fan, fans, module, radiator, relay, replace, tt, working  |
| Thread Tools |
Search this Thread |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
