How to get hood open when cable is broken or off!!
Old 12-24-2016, 11:22 AM
Cody Starke's Avatar
Default How to get hood open when cable is broken or off!!
So guys, I replaced my radiator and forgot the smallest little thing, the damn hood latch cable. But I found probably the easiest way to get the hood popped, so I thought I'd share incase any of you had that problem. Instead of trying to stick a pry bar up there and wiggle it around in the smallest spaces and having no working room, spend an extra 35+ dollars for an oil change . Sounds stupid right now, but once you remove the oil filter, there is a whole little alley way big enough you should be able to fit your hand up there and feel where the cable goes, and you can pop it with your hand. I got mine with ease when I thought I was screwed !!! Just thought I'd help out, it's have a 225 Quattro 6 speed roadster 🙏🏼
McQueen
06-29-2015 09:18 AM
ladybird
12-09-2013 02:45 PM
jzmuda
04-07-2008 10:09 PM
tjawad
12-04-2007 04:37 PM
Quick Reply: How to get hood open when cable is broken or off!!
